The Siebel Open UI client uses transition effects when you navigate between different screens and views. You can configure your preferred type of transition effect.
Note: Transition effects are limited in some deployments of the Siebel Open UI client. For more information about the transition effects available to you, contact your Siebel administrator. |
To set the transition effects
From the application-level menu, choose Tools, then User Preferences.
The User Preferences screen appears.
Navigate to the Behavior view.
The Behavior form appears.
From the drop-down list for the Transition field, choose from the available options.
