When you create a recurring activity, the End By field defaults to a predetermined value that is based on the value you select from the drop-down list for the Repeat Type field. You can change this predetermined value as needed.
Table 12-4 shows the default values for the End By field. For more information about creating recurring activities, see "Creating Recurring Calendar Activities".
