You can delete an activity from any calendar format in the Calendar screen. However, you cannot delete read-only activities. Read-only activities include the following activities:
Some activities imported from other applications, such as Microsoft Outlook or Microsoft Exchange.
Activities that you do not own in your calendar.
Activities that you can only view in the calendars of other users.
Activities that are protected by industry-specific functionality.
For example, some call records in Siebel Life Sciences are read-only. You can delete the call record, but not the calendar activity for the call record.
To delete an activity
Navigate to the Calendar screen.
In the daily, weekly, or monthly calendar format, click the hyperlink for an activity description to access the activity.
The Calendar Detail form appears.
Click Delete This One.
If you are the primary employee for the activity, then the activity is deleted from every participant's calendar. If you are a non-primary employee for the activity, then the activity is deleted from only your calendar.
