The iHelp Map is a view that displays the iHelp items available to you in the same format as the Site Map.
To use the iHelp Map
Do one of the following:
Choose Navigate, then Go to iHelp Map.
Choose Navigate, then Site Map, then iHelp Map, and then iHelp Map.
The iHelp Map screen appears.
To launch an iHelp item, click the iHelp item name.
