Table 7-3 shows compound query operators. In this table, operators appear in uppercase. However, query strings are case-sensitive. The operators do not have to be in uppercase.
When you perform a compound query, you must use parentheses to control the order in which the search for matching records is performed.
Table 7-3 Compound Query Operators
| Operator | Description | Example |
AND, and |
Placed between values, returns only records for which all the conditions are true. |
OR, or |
Placed between values, returns records for which at least one condition is true. |
NOT, not |
Placed before a value, returns only records that do not contain the value. |
Placed before and after the values and operators that are processed first, regardless of the default processing order. |
LIKE, like |
Placed before a value, returns records containing the value. |
The LIKE operator is case sensitive. To find matches regardless of case, see Table 7-2, "Simple Query Operators". |
