Buttons launch selection dialog boxes. Table 5-1 describes these buttons.
Table 5-1 Description of Select Buttons
| Button | Name | Description |
Single select button |
Launches a single selection dialog box. This dialog box applies to pick applets. |
Multiple select button |
Launches a multiple selection dialog box. This dialog box applies to Multi-Value Group (MVG) applets. |
Single selection dialog boxes allow you to add only one record to a field. In some cases, you can create a new record from the single selection dialog box.
Multiple selection dialog boxes allow you to select multiple records and add them to a field. In some cases, you can create a new record from the multiple selection dialog box.
