A selection dialog box can contain many records. You might find it necessary to search for the records you want to see in the list. You can perform full- or partial-text searches on one field.
Finding records is similar to querying for records, but you do not save search results when you find records.
Note: Unlike performing a query, any spaces you enter in the search field when finding records are included in the search. For example, if you are looking for a contact with the last name Smith, and enter Smith followed by a space in the search field, then any contacts with the last name Smith are not found because the Siebel application looks for each character (all the letters in Smith and a space). |
To find records in a selection dialog box
In the selection dialog box, select the field you want to search from the drop-down list for record fields.
In a multiple selection dialog box, the drop-down list for record fields appears above the list of available records, and not above the list of selected records.
Note: In the selection dialog box, you cannot select a date field. |
Type the text you want to search for in the field for a search value.
The field for a search value appears to the right of the drop-down list for record fields. A wildcard is automatically assumed at the end of text you enter in the field for a search value. If you search for Siebe, then all words beginning with the letters Siebe are found.
Search queries in pick lists are not case sensitive.
Click the right-arrow-in-a-circle icon.
The records matching your criteria appear.
