Siebel Hospitality Guide > Setting Up Charge Codes, Taxes, and Service Charges > Administering Service Charges >
Creating a Service Charge
Use the following procedure to define service charges for the property.
This task is a step in Administering Service Charges.
To create a service charge
  1. Navigate to the Tax Service Admin screen, then the Service Charges List view.
  2. In the Service Charges list, create a new record and complete the fields.
    Some of the fields are described in the following table.
    NOTE:  You can enter data in either the Amount or Percent field, but not both.
    Field
    Comments
    Name
    The name of the service charge.
    Description
    The description of the service charge.
    Percent
    Service charge expressed as a percentage. The service charge amount is calculated from this percent value multiplied by the price for the line item.
    Amount
    Service charge expressed as a flat fee. The flat fee is a preset amount.
    Start Date
    Date the service charge becomes active.
    End Date
    Date the service charge becomes inactive.
    Currency
    The monetary unit of measure.
    Taxable
    Check box that indicates whether or not the service charge is taxable.
    City
    City in which the service charge applies. A service charge might apply in many different cities, depending on the associated properties.
    State
    State in which the service charge applies. This field is automatically populated when the City field is completed.
  3. Save the record.
  4. If the service charge is taxable, click the link in the Name field, and select the Taxes view tab.
  5. In the Taxes list, create a new record, and from the Add Taxes dialog box, select the tax, and then click OK.
    NOTE:  The Taxable flag is for informational purposes only.
Siebel Hospitality Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
