Siebel Hospitality Guide > Managing the Function Space Diary in Siebel Open UI > Process of Configuring the Function Space Diary for Siebel Open UI >
Configuring Navigation from the Function Space Diary for Open UI to the Quote and Function Views
Administrators can use Siebel Tools to configure the Function Space Diary so that users can click a blocked function in the Function Space Diary and navigate to the corresponding quote or function view.
This task is a step in Process of Configuring the Function Space Diary for Siebel Open UI.
To configure navigation from the Function Space Diary to the Quote and Function views
  1. Start Siebel Tools.
  2. Search for the applet that is configured for the Function Space Diary
  3. To configure the Quote view drilldown, create a new drilldown object and set the values in the following table:
    Item
    Value
    Name
    Enter a name, for example, Booking Drilldown.
    Hyperlink Field
    Drill Down
    Source Field
    Drill Down
    View
    TNT SHM Quote Function Line Items View
    Business Component
    Quote
    Destination Field
    ID
    If you use this configuration, then the Date, Time, and Function details are carried over to the quote.
  4. Define the applet user properties in the following table:
    Item
    Value
    Name
    Pane 2 Field xxx (where xxx can be any integer)
    Value
    Quote Id,DDID
    Name
    Pane 2 Item Drilldown Name
    Value
    Booking Drilldown
  5. To configure the Function view drilldown, create a new drilldown object and set the values in the following table:
    Item
    Value
    Name
    Hyperlink Field
    Drill Down
    Source Field
    Drill Down
    View
    TNT SHM Function Line Item More Info View
    Destination Field
    ID
  6. Define the applet user properties in the following table:
    Item
    Value
    Name
    Value
    Function Id,DDID
    Name
    Value
    Booking Drilldown
  7. For more information on configuring navigation in Siebel Tools, see Using Siebel Tools.
Siebel Hospitality Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
