Default Timescale |
Time Scale Settings. Time intervals displayed in the diary views. |
Daily Start Time |
Time Scale Settings. Time at which the diary display begins. Applies to the Time Scale settings by Day only, for example, Day/Hour, Day/Day-Part, Day/Half-Hour, and Day/Quarter-Hour. |
Display |
Display Options. Enables you to change the information that is displayed in the Booking Bar in the Diary. |
Color By |
Display Options. Select a color scheme set up by the administrator in which to display bookings. |
Function Space Type Filter |
Display Options. Select the default option that you want to display in the Function Space Type field of the diary. |
Turn Times |
Display Options. Select to display the setup and tear-down times in the pattern configurable through CSS styling. Clear to show all bookings without turn-time indicators. However, warnings of turn-time conflicts are still displayed. |
Config Space Pattern |
Display Options. Select to display booked, configured spaces in a diagonal pattern. NOTE: It is recommended that you use different patterns for Config Space Pattern and Turn Times because both fields might be selected at the same time.
Show Unreserved |
Display Option. Shows Unreserved bookings in the Function Space Diary screen |
Drag/Drop Confirmation |
Advanced Settings. Controls when a validation pop up window should display when users drag and drop a booking. |
Weekend Color |
Color setting for Weekend days |
