Siebel Hospitality Guide > Managing the Function Space Diary in Siebel Open UI > Process of Managing the Function Space Diary in Siebel Open UI >
Assigning Category Bookings to Specific Spaces
If a revenue manager is satisfied with the specific space assignments that are displayed in the diary, then the manager can convert all category bookings for the day into specific space bookings. The function space inventory engine automatically accounts for new bookings as well as existing bookings and assigns the category bookings to the specific spaces. To assign category bookings to specific spaces
- Navigate to the Function Space Diary screen.
- In the Properties form, query for the property record.
- Click the appropriate view tab from one of the following: Sales/Execution, Revenue Management, Compact Diary, or Total Availability.
- Click the Menu button and select Assign to assign the category bookings to specific spaces.
Changing or Editing a Booking Inventory Status
Booking inventory records can be updated directly from within the diary views by double clicking the booking. You can double click on a booking and see a pop up with editable fields and additional actions. The pop up should also provide buttons to invoke additional actions. Each of the buttons will only be shown when applicable. If the button cannot be used, it will not be shown. To change a booking inventory status
- In the selected view, enter the required start date and select the required time scale.
- To make status changes, perform one or more of the operations described in the following table.
To Make This Status Change |
Unreserve a reserved booking |
Double-click the booking, and choose Unreserve. |
Based on the Unreserved option under the Display Options section in the filter panel, the booking may be visible or not in diary and the inventory status changes to Unreserved. |
Assign a specific space booking to a category |
Double-click the booking, and choose Assign to Category. |
The booking changes color to indicate that it is no longer assigned to a specific function space. |
Assign a category booking to a specific space |
Double-click the booking, and choose Assign to Specific Space. |
The booking changes color to indicate that it is no longer assigned to a category. |
Overbook an optioned booking |
Double-click the booking, and choose Overbook. |
The booking changes color to indicate that it is overbooked. |
Option an overbooked booking |
Double-click the booking, and choose Optioned. |
The booking changes color to indicate that it is not overbooked. |
Unreserve an optioned or overbooked booking |
The booking inventory status changes to Unreserved and the split may be removed or not from the indicator bar, based on the Unreserved selection under the Display Options section in the filter panel. |
Unreserve a reserved booking on the same indicator bar as an optioned booking |
The optioned booking inventory status changes to Option Reserved and the split may be removed or not from the indicator bar, based on the Unreserved selection under the Display Options section in the filter panel. |
Unreserve a reserved booking on the same indicator bar as an overbooked booking |
Double-click a reserved booking on the same indicator bar as an overbooked booking, and choose Unreserve. |
The overbooked booking inventory status changes to Reserved and the split may be removed or not from the indicator bar, based on the Unreserved selection under the Display Options section in the filter panel. |
Reserve an unreserved booking |
Double-click a reserved booking |
The inventory status changes to Reserved, if available. Otherwise, conflict dialog appears. |
Unreserve any booking (other than unreserved status) |
The inventory status changes to Unreserved and based on the Unreserved option under the Display Options section in the filter panel, the booking may be visible or not in diary. |
Copy |
Double-click the booking and choose Copy. |
The Copy window displays. |
Go To Function |
Double-click the booking and select Go To Function. |
Navigates to the function in Quotes Functions. |
Add a Function |
Double-click anywhere in the Function Space Diary. |
The Add Function window displays. |
To edit a booking
- Double-click on booking and complete some of the following fields as required.
Quote Name |
Function Information.The name of the quote. The quote name will be predefaulted with booking quote and cannot be changed. |
Function Name |
Function Information.The name of the function. The function name will be predefaulted with booking function. |
Function Type |
Function Information. The function type will be predefaulted with booking's function type. The options include the Function Type LOV values defined for the current property. |
Setup Style |
Function Information. The setup style will be predefaulted with booking function's setup style. Setup styles that have been defined as universally available appear in the list. For more information about setup styles, see Chapter 5, "Setting Up Function Spaces, Sleeping Rooms, and Suites," and Chapter 9, "Defining Day Parts, Status Indicators, and Setup Style Translations." |
Function Status |
Function Information. The function status will be predefaulted with booking's function status. |
Function Space |
Function Information. The function space will be predefaulted with booking's function space. |
Function Date |
Function Timing. The date of the function. The function date will be predefaulted with booking's function date. |
Start Time |
Function Timing. The start time of the function. The start time will be predefaulted with booking's function start time. |
End Time |
Function Timing. The end time of the function. The user can specify a start time and an end time and the duration is automatically calculated. The end time will be predefaulted with booking's function end time. |
Expected |
Attendees. The expected number of attendees for the function, from the estimates provided by the customer. Expected will be predefaulted with booking's function expected quantity |
Set |
Attendees. The set number of attendees for the function, from the estimates provided by the customer. Set will be predefaulted with booking's function set quantity. |
Guaranteed |
Attendees. The Guaranteed number of attendees for the function, from the estimates provided by the customer. This field is prepopulated with the booking's function Guaranteed quantity. |
- Click OK.
If there is a conflict, you will receive a booking conflict error. You can select overbook, option or create an unreserved function
