Siebel Hospitality Guide > Managing the Function Space Diary in Siebel Open UI > Process of Managing the Function Space Diary in Siebel Open UI >
Adding a Function in the Function Space Diary View for Siebel Open UI
The following procedures detail how to add functions in the Function Space Diary view.
To add a function in the Function Space Diary view
  1. Navigate to the Function Space Diary screen.
  2. Click the menu button, and then click Add Function.
  3. Complete the fields as required. Some fields are described in the table that follows.
    Field
    Comments
    Quote Name
    Function Information.The name of the quote. Quote name will be predefaulted if drilling down from a quote, otherwise quote field will be null and user will need to select a quote.
    Function Name
    Function Information.The name of the function.
    Function Type
    Function Information. The type of function that is planned. The options include the Function Type LOV values defined for the current property.
    Setup Style
    Function Information. The setup style for the function. Setup styles that have been defined as universally available appear in the list. For more information about setup styles, see Chapter 5, "Setting Up Function Spaces, Sleeping Rooms, and Suites," and Chapter 9, "Defining Day Parts, Status Indicators, and Setup Style Translations."
    Function Status
    Function Information. Predefaulted with the selected quote status.
    Function Space
    Function Information. The type of function space that is planned. The options include the function spaces configured for the current property.
    Function Date
    Function Timing. The date of the function.
    Start Time
    Function Timing. The start time of the function.
    End Time
    Function Timing. The end time of the function. The user can specify a start time and an end time and the duration is automatically calculated.
    Expected
    Attendees. The expected number of attendees for the function, from the estimates provided by the customer.
    Guaranteed
    Attendees. The Guaranteed number of attendees for the function, from the estimates provided by the customer.
    Set
    Attendees. The set number of attendees for the function, from the estimates provided by the customer.
  4. Click Add Function.
    If there is a conflict, then you receive a booking conflict error. You can select overbook, option or create an unreserved function.
Siebel Hospitality Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
