Siebel Hospitality Guide > Defining Day Parts, Status Indicators, and Setup Style Translations > Setting Up Property Day PartsBefore the Function Space Diary can be used, either the administrator or the corporate revenue manager must segment the operational day into periods of time and then set up these day parts for the Function Space Diary. Display day parts are set up at the corporate level and then applied to each property. In the Function Space Diary, the user can select the Day/Day-Part display option to view each day with the time axis divided into the defined day parts. NOTE: It is recommended that administrators activate the Audit Trail option so that changes to existing records are tracked. The Audit Trail Engine must be configured to use the Audit Trail option. For more information on configuring and using Audit Trail, see Siebel Applications Administration Guide. This task is a step in Process of Defining Day Parts, Status Indicators, and Setup Style Translations.
| Siebel Hospitality Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
