Siebel Hospitality Guide > Defining Day Parts, Status Indicators, and Setup Style Translations > Defining Function Space and Asset Inventory Status Indicators >
Defining Display Options for Child Functions and Dependencies
You can define the display options for child functions and child dependencies for detailing and space holds in the Function Space Diary. For more information about detailing and child functions (also known as subfunctions), see About Function Detailing.
This task is a step in Defining Function Space and Asset Inventory Status Indicators.
To define display options for child functions and dependencies
  1. Navigate to the Function Space Administration screen, then the Function Space Diary Administration view.
  2. In the FSD Administration form, complete the fields under the Detail/Space Hold Information heading.
    Some fields are described in the following table.
    Field
    Comments
    Show Child Functions
    Select the check box to display child functions in the Function Space Diary.
    Show Child Dependencies
    Select the check box to display child dependencies in the Function Space Diary.
    Child Pattern
    Select a pattern in which to display child functions in the Function Space Diary. Child functions are displayed with the same color values as the parent, and with the pattern you select in this field.
  3. In the Function Color Schema list, add records for the appropriate inventory statuses.
    Options for detailing are described in the following table.
    Inventory Status
    Comments
    Child Dependency
    Select a color to denote child dependencies in the Function Space Diary.
    Detail Reserved
    Select a color to denote detailed functions and subfunctions in the Function Space Diary.
    NOTE:  It is recommended that you select colors for child functions and dependencies that are different from the colors for parent functions and dependencies, so that parent and child items will look different in the Function Space Diary.
Siebel Hospitality Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
