Siebel Hospitality Guide > Getting Started with Siebel Hospitality > Process of Configuring Opportunities and Quotes > Disabling Opportunity Revenue UpdatesWhen a quote of an opportunity is set to Definite, then by default, Siebel Hospitality updates the revenue of the associated opportunity from the revenue of the Definite quote. However, you can disable this update. When a quote of an opportunity is set to Definite, what happens to the revenue of that opportunity is controlled by the value of the TNT SHM Update Opty Rev - Disable user property. The possible TNT SHM Update Opty Rev - Disable user property values are as follows:
If you change this user property, you must make the change in the TNT SHM Function Revenue Service business service and in the business component currently used in your UI view. This user property appears in each of the Siebel application objects listed in the table that follows. This user property works together with the TNT SHM Disable Accept Quote field. If you allow multiple quotes to go Definite (that is, if you change the value of the TNT SHM Disable Accept Quote field to Y), it is recommended that you disable the update to the revenue of an opportunity from the revenue of the Definite quote. For more information about the TNT SHM Disable Accept Quote field, see Configuring Multiple Quotes to Go Definite. To disable the update to opportunity revenue from the revenue of the Definite quote, follow this procedure. This task is a step in Process of Configuring Opportunities and Quotes. To disable opportunity revenue updates
For more information about changing the values of objects in Siebel Tools, see the chapter on working with objects in Using Siebel Tools. |
| Siebel Hospitality Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
