Siebel Hospitality Guide > Managing Hospitality Inventory > Managing Functions That Require Backup SpaceThere are two ways in which function spaces can be mapped to different functions:
When you add a new function space to a quote, you must determine whether or not it requires backup space. This is determined by examining the read-only Back Up Required field for the function or function space. If this flag is checked, add extra backup spaces as required. NOTE: You cannot delete the Active Primary space for a function. If you want to remove the active primary space for a function, you must make another space the active primary space, and then delete the space that is no longer the active primary space. This task is a step in Process of Managing Hospitality Event Inventory. To manage functions that require backup, you must do the following: |
| Siebel Hospitality Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
