Siebel Hospitality Guide > Managing Hospitality Inventory > Changing Inventory-Critical Reservation Attributes > About Inventory-Critical Fields at the Room Block LevelInventory critical fields also exist at the room block level. In a process similar to that which occurs at the function level, Siebel Hospitality monitors for changes and verifies that the records are valid after each update. If multiple updates occur for a reserved room block record, a message appears that provides a suggested course of action. About Date and Time ChangesWhen the user updates either the Date or the Day # field for a reserved room block, the same process occurs as when changes are made at the function level. For more information, see About Inventory-Critical Fields at the Function Level. About Room Block Changes and Availability ChecksWhen the user increases the room block for a reserved room block record, a message alerts the user that an availability check must be performed. The standard reservation process is followed, and the user can either save the changes with a Reserved or Unreserved Inventory Status, or click Cancel to restore the original Blocked values. |
| Siebel Hospitality Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
