Siebel Hospitality Guide > Managing Nonparticipating Properties > Setting Up Nonparticipating PropertiesNonparticipating properties are set up by the administrator when the property records are created in the Siebel Hospitality database. For more information about setting up nonparticipating properties, see Setting Up Nonparticipating Properties. When you have identified a property as nonparticipating, it is advised that you create one function space, one sleeping room, and one catering product, which can be used when an opportunity is generated from a quote. For more information about adding function spaces, sleeping rooms, and catering products to a property record, see Setting Up Function Spaces, Sleeping Rooms, and Suites. This task is a step in Process of Managing Nonparticipating Properties. |
| Siebel Hospitality Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
