Siebel Hospitality Guide > Capturing Hospitality Opportunities > Selecting Properties for an Event Opportunity > Searching for Properties for an OpportunityThe Property Locator can be used to find properties in a particular region or area. The Property Locator is available from the Property screen. When you search for a property in the Property Locator, you must enter address details in the search fields. You can also enter other details about the property, such as market segment, brand, or facilities information. However, the Property Locator is primarily a tool for locating properties in a particular area or region. When you have used the Property Locator to find a list of possible properties, you can choose the appropriate property using the Properties list. This task is a step in Selecting Properties for an Event Opportunity. To search for properties for an opportunity
| Siebel Hospitality Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
