Siebel Hospitality Guide > Capturing Hospitality Opportunities >
Viewing Opportunity Details with the Opportunity Explorer
The Opportunity Explorer can be used to view details about all opportunities in Siebel Hospitality. However, it can be especially useful when dealing with recurring events and host-affiliate opportunities. The Opportunity Explorer allows you to view details about an opportunity by selecting the opportunity in an explorer window and then using the folders in the explorer window to view the details. This task is a step in Process of Capturing Hospitality Opportunities. To view opportunity details with the Opportunity Explorer
- Navigate to the Opportunities screen, then the Opportunity Explorer view.
- In the Opportunities list, query for and select the opportunity record in the Explorer pane on the left side of the screen.
- Use the opportunity subfolders to review the opportunity details.
