Siebel Hospitality Guide > Setting Up Pricing and Property Pricing >
Defining Future Date Adjustments for Revenue Categories
Property administrators can define future date adjustments on the pricing of revenue categories. This means at a certain date in the future, the prices of all products in a certain category will increase by the defined percentage. This markup is rolled up into each individual quote when the quote price is calculated.
This task is a step in Process of Setting Up Product and Property Pricing.
To define a future date adjustment for a revenue category
  1. Navigate to the Property Pricing Admin screen, then the Properties view.
  2. In the Properties list, select the property and click the link in the Property Name field.
  3. Click the Future Date Adjustment view tab.
  4. In the Future Date Adjustments list, create a new record.
  5. In the new record, complete the fields and save the record.
    The following table describes some of the fields.
    Field
    Comments
    Name
    The name of the adjustment to be applied.
    Revenue Category
    The category to which the adjustment is to be applied.
    NOTE:  You must select a category in this field or the adjustment will not be applied.
    Revenue Parent Category
    This field is automatically populated when the Revenue Category field is completed.
    Start Date
    The date from which the future date adjustment is to be applied.
    Start Day
    This field is automatically populated when the Start Date field is completed.
    End Date
    The date on which the future date adjustment is no longer valid.
    End Day
    This field is automatically populated when the End Date field is completed.
    % Markup
    The percentage increase on all products in the category.
Siebel Hospitality Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
