Siebel Hospitality Guide > Setting Up Pricing and Property Pricing > Setting Up Volume Discounts > Creating Aggregate Volume Discounts for Sleeping Rooms and SuitesA sleeping room aggregate volume discount is a volume discount that applies to all types of sleeping rooms at a specific property. Siebel Hospitality allows you to create aggregate volume discounts for sleeping rooms. For example, a property has three different types of sleeping rooms (single room, double room, and penthouse suite). A customer books 10 rooms of each type, which means the customer books a total of 30 rooms. Instead of giving a separate discount for each room type, you can give the customer one aggregate discount for all 30 rooms. Before you perform this procedure, you must create a volume discount, as described in Creating Volume Discounts. Additionally, you must add line items to the volume discount, as described in Adding Volume Discount Line Items. To create an aggregate volume discount for sleeping rooms and suites
| Siebel Hospitality Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
