Siebel Hospitality Guide > Setting Up Pricing and Property Pricing > Setting Up a Matrix Series >
About Matrix Discount Adjustment Types
The Adjustment Type field allows you to specify the type of adjustment to apply to matrix discounts. Selection options are as follows:
  • Discount Amount. Indicates that a set amount is to be discounted from the product price.
  • % Discount. Indicates that a set percentage is to be discounted from the product price.
  • Markup Amount. Indicates that the product price is to be increased by a set amount.
  • % Markup. Indicates that the product price is to be increased by a set percentage.
  • Price Override. Indicates that the price of the product is to be overridden to the amount specified in the Adjustment Amount field.
  • Tier Based. Applies the discount percentage defined by each Volume Discount Line Item record to the quantity of items defined in that Volume Discount Line Item record.
  • Multiplicative Amount. Multiplies the target price by the specified adjustment value.
  • Power (Target Price, Power). Raises the target price to the specified exponential value. For example, if the target price is 4, and the adjustment value is 2, the new price will be 4 to the 2nd power (4 * 4) = 16.
  • Round (Current, Decimal Places). Sets the number of decimal places to which the price will be rounded.
Siebel Hospitality Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
