Siebel Hospitality Guide > Setting Up Products and Assets > Process of Setting Up Hospitality Products >
Creating Simple Hospitality Products
In Siebel Hospitality, a simple product is a single component product, such as table, chair, beverage, and so on. You can create simple products that can then be grouped to create complex products. For more information about creating products, see the chapter on basic product administration in Siebel Product Administration Guide.
This task is a step in Process of Setting Up Hospitality Products.
To create a simple Hospitality product
  1. Navigate to the Administration - Product screen, then the Products view.
  2. In the Products list, create a new product record, and complete the fields as required.
    Some fields are described in the following table.
    Field
    Comments
    Name
    The product name.
    Part #
    The part number for the product.
    Type
    The type of product. Examples are Menu, Package, Sleeping Room, and Setup Style.
    Organization
    Automatically populated with the name of the default organization. You can change the selection. You can add multiple organizations, specifying one as the primary.
    Unit of Measure
    The unit of measure used for the product. For example, if coffee is the product, the unit of measure might be pounds.
    Revenue Subcategory
    The revenue subcategory for the product.
    Revenue Category
    Automatically populated when a revenue subcategory is selected.
    Parent Revenue Category
    Resource Type
    Determines whether or not the item is automatically reserved for an event. Available values are Critical, General, and Non-Critical. For more information about these values, see About Hospitality Assets.
    Set-Up Time
    Minutes necessary to set up a product.
    Tear-Down Time
    Minutes necessary to tear down a product.
    Property
    The property at which this product is available.
    Billable Flag
    Select to charge the customer for use of the product. Clear to designate this product as free of charge.
    For example, you might charge customers for bottles of champagne, but you might not charge customers for the use of a table and chairs.
    Grouping
    Allows you to group products to facilitate searches for products, for example, to find all dinner main courses available at a particular property.
    Report Header
    Select a report header for the product.
  3. Click Release to make the product take effect.
Siebel Hospitality Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
