Siebel Hospitality Guide > Setting Up Products and Assets > Process of Adding Catalog Visibility to Hospitality Products >
Adding Products to Catalogs and Categories
After you have created product catalogs and categories, you can add products to them.
This task is a step in Process of Adding Catalog Visibility to Hospitality Products.
To add products to catalogs and categories
  1. Navigate to the Administration - Catalog screen, then the Catalog Administration view.
  2. In the Catalog Administration list, query for and select the required catalog.
  3. Drill down on the Name hyperlink, and select the required category in the Categories list.
  4. Scroll down, click the Categories view tab, and then click the Products list.
  5. In the Products list, create a new record.
  6. In the Add Internal Products dialog box, query for and select the required product, and click OK.
    The selected product appears in the Products list. Most fields are populated when the product has been selected.
  7. Add more products, as required.
  8. (Optional) In the Sequence # fields, specify the sequence in which to display the products in the catalog.
Siebel Hospitality Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
