Siebel Hospitality Guide > Setting Up Properties > Process of Adding Property Floor Plans >
Attaching a Floor Plan to a Property
To attach a floor plan to a property, follow this procedure. This task is a step in Process of Adding Property Floor Plans. To attach a floor plan to a property
- Navigate to the Property Administration screen, then the Properties view.
- In the Properties list, query for the required property record.
- Drill down on the Property Name hyperlink.
- Click the Floor Plans view tab.
- In the Floor Plan list, create a new record, and complete the fields.
The following table describes some of the fields.
Name |
Name of the floor plan for the function space. |
Description |
Description of the floor plan. |
Image File Name |
Floor plan image. Attach an image from the picklist. To attach a floor plan image that is not in the picklist, add a New Literature item of type Bitmap or Thumbnail Image. For more information about adding literature records, see Siebel Applications Administration Guide. |
Image File Type |
Type of the floor plan image, either Bitmap or Thumbnail Image. |
Thumbnail Image File Name |
Thumbnail image of the floor plan. |
Thumbnail Image File Type |
Type of the floor plan thumbnail image, either Bitmap or Thumbnail Image. |
After you add a record to the Floor Plan list, sales representatives can view the floor plan in the Property screen, Floor Plans view for the property.
