Siebel Hospitality Guide > Setting Up Properties > Process of Setting Up Property Clusters >
Creating a Property Cluster
The following procedure describes how to create a property cluster. This task is a step in Process of Setting Up Property Clusters. To create a property cluster
- Navigate to the Clusters screen, then the Clusters view.
- In the Clusters list, create a new record, and complete the fields.
The following table describes some of the fields.
Cluster Id |
The identification number of the cluster. This field is automatically populated. |
Description |
A description of the purpose of the cluster. |
Last Updated By |
Read only. Automatically populated with the User Id of the last person to update this record. |
Last Updated Date |
Read only. Automatically populated with the date on which this record was last updated. |
Name |
The name of this cluster. |
Type |
The type of cluster, either Revenue Cluster or Sales Cluster. |
- Drill down on the Cluster Id hyperlink, and click the Properties tab.
- In the Properties list, create a new record.
- In the Add Properties dialog box, query for the property to add to this cluster, select the property, and click OK.
Siebel Hospitality redisplays the Properties list with a new record. The fields in the list record display the details of the property you selected in the Add Properties dialog box.
- Add more properties to the list as required.
