Siebel Hospitality Guide > Setting Up Properties > Process of Setting Up Property Clusters > Viewing Cluster RecordsIf a property is in a cluster assigned to a user, that user has visibility to the records associated with the property, even if the user is not specifically assigned to that property. Records for the property, however, will only be available to that user in the Clusters visibility filter in the list of records, and not in any other visibility filter. To view cluster records, follow this procedure. This task is a step in Process of Setting Up Property Clusters. |
| Siebel Hospitality Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
