Siebel Hospitality Guide > Applying Quote and Order Pricing > About Quote Pricing for Meeting Packages > About Mapping Rental Allocations to Function Space Line ItemsRental allocation is a per-person cost. Because multiple function spaces can be assigned to each function, only the primary function space receives the rental allocation. In the primary function space record, the Negotiated Price of the function space line item is calculated as Rental Allocation multiplied by Expected. If the primary function space is changed to a different function space, the following actions occur. Previous space. The previous primary function space line item field values are changed as follows: New space. The new primary function space line item field values are changed as follows: |
| Siebel Hospitality Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
