Siebel Hospitality Guide > Managing Property-Specific Event Quotes > Managing Functions Associated with Quotes > Changing Function Spaces with Product FeaturesIf product features are specified as part of the function agenda in the opportunity, these features are copied to the functions when a quote is created. They are visible in the Quotes Functions view. If you then attempt to change the function space selected by the create quote best fit process to a space that does not contain the requested features, an error message appears. The new choice for function space is accepted only if it can also support the specified product feature. This topic is a step in Managing Functions Associated with Quotes. |
| Siebel Hospitality Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
