Siebel Hospitality Guide > Managing Property-Specific Event Quotes > Reviewing Quote Discounts > Reviewing Room Block DiscountsDiscounts can be applied to room blocks and line items through volume discounts, a matrix series, or by manually applying a discount to a function line item. For more information about volume discounts and matrix series, see Administering Discount Pricing. You can view the discount amount for each individual room block line item and also the total discount for the room block through the Quotes screen, Room Blocks view. When you have viewed the discounts applied to a function and the line items of that function, you can decide whether or not the discount is appropriate. If you want to manually override all prices and apply a manual discount price, see Applying a Negotiated or Discount Price to Line Items To view the discount amount for a room block line item
To view the total discount amount for a room block
| Siebel Hospitality Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
