Implementing Siebel Business Applications on DB2 for z/OS > Customizing a Development Environment >
Converting Nonpartitioned Tables to Partitioned Tables
Siebel Business Applications support two scenarios for converting nonpartitioned tables to partitioned tables.
NOTE:  In the following scenarios, source table refers to your current nonpartitioned table, and target table refers to the destination partitioned table.
  • Source table and target table are defined in different table spaces.
    If the source table and target table are defined in different table spaces, and the target table space is a new table space that does not yet exist in your current database, no special action is required. Run the two utilities available in the Database Configuration Wizard (Migrate Repository and Synchronize Schema Definition) to automatically rebuild the table in the new partitioned table space and remove the original table from the database.
  • Source table and target table are defined in the same table space.
    Database operations do not support rebuilding a table space from nonpartitioned to partitioned. Therefore, if the source table and target table are defined in the same table space (for example, if you used the dbconf.xls spreadsheet to convert an existing table space from nonpartitioned to partitioned), you must perform one of the following procedures (as appropriate for your configuration) to convert the nonpartitioned table to a partitioned table.
To convert to a nonpartitioned table for a partitioned table space configuration
  1. Use your preferred database tool to manually move every nonpartitioned table (every table that you intend to convert) to a temporary table space, and then use the SQL DROP command to remove the original table space.
  2. Use the Siebel Database Storage Configurator (dbconf.xls) to modify the storage control file, changing the mode of the table spaces to partitioned.
    For further information, see About Modifying Storage Control Files.
  3. Run the Database Configuration Wizard and select the Migrate Repository option. This process automatically rebuilds the source tables in the new partitioned table space and removes the original nonpartitioned table.
  4. Manually remove the temporary table space that you created in Step 1 from the database.
To convert nonpartitioned tables to partitioned tables using alternate tools
  • You can use alternate tools (for example, BMC Change Manager or IBM Compare Utility) to convert nonpartitioned tables to partitioned table spaces. In this case, after applying all changes, change the schema version by executing the following SQL:
    update S_APP_VER
    set CUSTOM_SCHEMA_VER = char(integer(CUSTOM_SCHEMA_VER) + 1)
    This SQL is stored in ddlview.sql and can be executed outside of the Siebel application.
Implementing Siebel Business Applications on DB2 for z/OS Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
