Implementing Siebel Business Applications on DB2 for z/OS > Preparing for Implementation on the DB2 Host > Performing Postinstallation Tasks for DB2 Connect > Defining a Database Alias and Testing a ConnectionThis topic describes how to define a database alias and test a connection. When you create a connection to DB2 on z/OS, the connection is defined with a database alias that has the appropriate connection information for your database. This alias is the connect string that you specify when you install the Siebel Server. Record the connect string in the copy you made of Deployment Planning Worksheet. To define your database alias, use the DB2 Configuration Assistant or the DB2 Command Line Processor. For information on setting values in the db2cli.ini file and for using the DB2 Configuration Assistant or Command Line Processor, refer to the relevant IBM documentation. NOTE: When you define database aliases, you must add the Testing the Database Connection in a Windows EnvironmentUse the following procedure to test the database connection in a Windows environment. To test the database connection on the Windows platform
Alternatively, you can use the DB2 Command Window or the DB2 Command Line Processor to test the database connection by typing the following, then pressing Enter: DB2 connect to database_alias user database_userID using database_password
If the connection is successful, database connection information appears. Testing the Database Connection in a UNIX EnvironmentUse the following procedure to test the database connection in a UNIX environment. |
| Implementing Siebel Business Applications on DB2 for z/OS | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
