Implementing Siebel Business Applications on DB2 for z/OS > Preparing for Implementation on the DB2 Host > Performing Postinstallation Tasks for DB2 ConnectThis task is a step in Process of Setting Up DB2 Connect. After installing DB2 Connect, applying the necessary IBM Fix Pack, and setting up the network connectivity (TCP/IP and FTP) from the DB2 Connect server to the mainframe, there are a number of additional steps you must perform to use DB2 Connect with Siebel Business Applications. These steps include: |
Implementing Siebel Business Applications on DB2 for z/OS | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
