Implementing Siebel Business Applications on DB2 for z/OS > Preparing for Implementation on the DB2 Host > Process of Setting Up DB2 Connect > Configuring DB2 Connect PE to Support Siebel Developer Web ClientThis task is a step in Process of Setting Up DB2 Connect. Using DB2 Connect PE to support the Siebel Developer Web Client involves:
With this approach, a user on a Siebel Developer Web Client connects directly to DB2, as shown in the upper part of Figure 1. To connect to DB2 using DB2 Connect PE
| Implementing Siebel Business Applications on DB2 for z/OS | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
