Implementing Siebel Business Applications on DB2 for z/OS > Preparing for Implementation on the DB2 Host > About Connecting to the Database Using DB2 ConnectYou install the Siebel Schema on DB2 for z/OS using the Database Configuration Wizard which resides on a client Siebel Server. For a description of the installation process, see Installing the Siebel Database on the DB2 Host. After installation, you execute SQL on the DB2 for z/OS host. Configuration Options for DB2 ConnectWhen using DB2 Connect, your configuration options depend on whether you are deploying Siebel Business Applications on a Web Client or on a Developer Web Client, as shown in Table 3.
Figure 1 illustrates some of the configurations possible with DB2 Connect Personal Edition (PE) and DB2 Connect Enterprise Edition (EE). DB2 Connect PE runs on the workstation only; DB2 Connect EE can run on the same computer as the Siebel Server or on a different computer. The configuration you choose largely depends on the types of Siebel clients your enterprise supports. For detailed information about DB2 Connect, refer to the IBM documentation. |
| Implementing Siebel Business Applications on DB2 for z/OS | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
