Implementing Siebel Business Applications on DB2 for z/OS > Preparing for Implementation on the DB2 Host > About the Required IBM Fix PacksAfter you have installed DB2 Connect, install any relevant IBM Fix Packs. To find out which IBM Fix Pack you need to use, refer to Siebel System Requirements and Supported Platforms on Oracle Technology Network or the vendor documentation. Refer to IBM documentation for installing the Fix Pack for your environment. NOTE: When using UNIX operating systems, if you install an IBM Fix Pack after you create the DB2 database instance, you must update the instance using the db2iupdt command. You can verify the currently installed version of DB2 Connect and the IBM Fix Pack by running the command db2level from the DB2 Command Window. In a UNIX environment, this command is run from a UNIX shell after sourcing the appropriate db2profile. Make a note of the information and compare the Informational tokens from the output against Siebel System Requirements and Supported Platforms on Oracle Technology Network. In addition to IBM Fix Pack information, the Siebel System Requirements and Supported Platforms on Oracle Technology Network contains any other installation requirements. |
| Implementing Siebel Business Applications on DB2 for z/OS | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
