Implementing Siebel Business Applications on DB2 for z/OS > Configuring the Siebel Database Layout > About Siebel Objects > Buffer Pools Used in Storage Control FilesSiebel Business Applications use four buffer pools in the storage control file templates:
Multiple buffer pools can be used for each page size. If you require multiple buffer pools, use the Siebel Database Storage Configurator (dbconf.xls) or any other method described in Preparing a Storage Control File to enter these values. Your DBA must activate and grant use of buffer pools before you can perform the Siebel installation. For an example of buffer pool definitions, see Allocating Space for Buffer Pools and Storage Groups. |
| Implementing Siebel Business Applications on DB2 for z/OS | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
