Implementing Siebel Business Applications on DB2 for z/OS > About Siebel Table Partitioning >
Prepartitioned Siebel Tables
Siebel Business Applications provide the partitioned tables shown in Table 6 in the storage control file templates. The database tables listed represent partitioned Core product tables; seven exceptions are identified as Siebel Industry Applications (SIA) product tables.
For each table in Table 6, the partitioning key columns for the table are listed, as is the recommended clustering index for the table. A partitioning index is defined for three of the partitioned tables (S_CONTACT, S_OPTY and S_ORG_EXT); the name of the index is listed for these tables.
When determining the partitioning strategy for your implementation, you must assess whether the partitioning key columns and recommended clustering indexes specified for the prepartitioned tables are appropriate for your environment. For example, in assessing the most appropriate partitioning column to use for intersection tables, take into account the relationship of candidate partitioning columns to their respective parent tables. Additionally, if multiple organizations are defined in your Siebel application, the BU_ID column might be the most appropriate partitioning column for a table. For information on customizing partitioned tables, see Changing the Number of Table Space Partitions.
Table 6. Prepartitioned Siebel Tables with Physical Columns
Table
Partitioning Key Columns
Recommended Clustering Index
S_ACT_EMP
PARTITION_COLUMN
S_ACT_EMP_M1
S_ADDR_ORG
PARTITION_COLUMN
S_ADDR_ORG_U1
S_ADDR_PER
PARTITION_COLUMN
S_ADDR_PER_U1
S_APPLD_CVRG
Siebel Industry Applications (SIA) table
PARTITION_COLUMN
S_APPLD_CVRG_U1
S_ASSET
PARTITION_COLUMN
S_ASSET_U1 (ASSET_NUM, PROD_ID, REV_NUM, BU_ID, CONFLICT_ID)
S_ASSET_CON
PARTITION_COLUMN
S_ASSET_CON_U1 (ASSET_ID, CONTACT_ID, RELATION_TYPE_CD, CONFLICT_ID)
S_ASSET_POSTN
PARTITION_COLUMN
S_ASSET_POSTN_M1
S_COMMUNICATION
PARTITION_COLUMN
S_COMMUNICATION_U1
S_CONTACT
A partitioning index, S_CONTACT_M12, is defined for this table.
LAST_NAME
NOTE:  If multiple organizations are defined in your Siebel application, the BU_ID column might be a more effective partitioning key than the LAST_NAME column. In this case, cluster on the S_CONTACT_M14 index (BU_ID, LAST_NAME, FST_NAME, PRIV_FLG).
S_CONTACT_M12 (LAST_NAME, FST_NAME, MID_NAME, PRIV_FLG, ALIAS_NAME)
S_EVT_ACT
PARTITION_COLUMN
S_EVT_ACT_P1
S_EXP_ITEM
PARTITION_COLUMN
S_EXP_ITEM_U1
S_FN_ACCNT_TXN
PARTITION_COLUMN
S_FN_ACCNT_TXN_U1
S_FNCVRG_ELMNTS
PARTITION_COLUMN
S_FNCVRG_ELMNTS_U1
S_INS_CLAIM
PARTITION_COLUMN
S_INS_CLAIM_U1
S_INS_ITEM
PARTITION_COLUMN
S_INS_ITEM_U1
S_INSCLM_ELMNT
PARTITION_COLUMN
S_INSCLM_ELMNT_U1
S_OPTY
A partitioning index, S_OPTY_U1, is defined for this table.
NAME
NOTE:  If multiple organizations are defined in your Siebel application, the BU_ID column might be a more effective partitioning key than the NAME column. In this case, cluster on the BU_ID, NAME columns.
S_OPTY_U1 (NAME, PR_DEPT_OU_ID, BU_ID, CONFLICT_ID)
S_OPTY_POSTN
PARTITION_COLUMN
S_OPTY_POSTN_U1 (OPTY_ID, POSITION_ID, CONFLICT_ID)
NOTE:  If your Siebel application is configured to use My Views to access the S_OPTY_POSTN table by the POSITION_ID column, cluster on the S_POSTN_CON_M12 index.
S_ORG_EXT
A partitioning index, S_ORG_EXT_U1, is defined for this table.
NAME
S_ORG_EXT_U1 (NAME, LOC, BU_ID, CONFLICT_ID)
S_PARTY
PARTITION_COLUMN
S_PARTY_P1
S_PARTY_REL
PARTITION_COLUMN
S_PARTY_REL_U1
S_POSTN_CON
PARTITION_COLUMN
S_POSTN_CON_M1 (POSTN_ID, CON_LAST_NAME, CON_FST_NAME)
NOTE:  If the S_POSTN_CON table is not implemented as partitioned, cluster on either the POSTN_ID or the CON_ID column, depending on the one-to-many relationship of each column to its parent table.
S_REVN
PARTITION_COLUMN
S_REVN_U1 (REVN_ITEM_NUM, BU_ID, CONFLICT_ID)
S_SRV_REQ
PARTITION_COLUMN
S_SRV_REQ_U1 (SR_NUM, BU_ID, CONFLICT_ID)
Implementing Siebel Business Applications on DB2 for z/OS Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
