Implementing Siebel Business Applications on DB2 for z/OS > About Siebel Table Partitioning > Considerations in Partitioning Tables > About Choosing a Partitioning Key ColumnYou can use any column from a Siebel base table as the partitioning key for a Siebel table but you cannot use extension columns you create for partitioning purposes. In deciding which column is most appropriate for partitioning, consider data access and data distribution factors. You also need to determine the number of partitions your implementation requires. When choosing a partitioning key for a Siebel table, follow all the rules, restrictions, and concerns listed in the IBM DB2 documentation. Factors to consider include data distribution and potential updates of partitioning keys. For example, when partitioning keys are updated, system performance is adversely affected. When choosing partitioning keys, select fields that are seldom updated, when possible. This helps avoid performance problems. The partitioning key that provides optimum performance and scalability varies according to the type of table being partitioned. For example, if in an organization Contact records are retrieved by LAST_NAME range predicates, for example, However, a different approach is required for child tables, especially those in a one-to-many (1:M) relationship with the parent table. If child tables are partitioned, it is recommended that you use the PAR_ROW_ID column for both the partitioning and clustering keys to reduce the input/output steps required to return related child records. As an alternative to using Siebel table columns as partitioning keys, you can use either the Siebel PARTITION_COLUMN or MEMBER_NAME columns. These columns are used for partitioning purposes only. The PARTITION_COLUMN column is a physical column that is defined in the storage control file, but is not accessed by the Siebel application. It exists to provide a method of ensuring even data distribution across table partitions where none of the table columns are good candidates for partitioning. The column is populated with data using a trigger to generate the partitioning value for each row. For additional information on the role of PARTITION_COLUMN, see Partitioning for Even Data Distribution. For information on the role of the MEMBER_NAME column, see Partitioning Strategies for Special Types of Tables. |
| Implementing Siebel Business Applications on DB2 for z/OS | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
