Siebel Life Sciences Guide > Configuring Data for Oracle Pharma Sales Analytics > Creating Target Lists Using Oracle Business Intelligence > Using Target List Creator with Siebel Pharma Applications in Connected ModeYou can also use the Target List Creator with the Siebel Pharma application and Oracle Pharma Sales Analytics in connected mode. This topic lists the tasks that you must carry out to verify the Siebel Pharma application's configuration to support using the Target List creator in connected mode:
Install and Configure the Oracle Business Open Intelligence InterfaceThe LS Analytics Target Service business service uses an ODBC DSN to connect back to the Oracle BI Server and execute the Oracle BI logical SQL passed into it. This ODBC DSN needs to be setup using the Oracle BI Open Intelligence Interface (ODBC) client, and requires that this client be installed on the Siebel Pharma application server. To install and configure the Oracle BI Open Intelligence Interface, see Oracle Business Intelligence Applications Installation and Configuration Guide. Configuration Changes to the Siebel Business ApplicationTo enable the LS Analytics Target Service Business Service to be called from the Siebel Web Engine (SWE), the Business Service name has to be present as a ClientBusinessService user property for the Siebel Business Application being used. To verify the LS Analytics Target Service business service
Configuring the Application's Server Component Parameters and Enterprise ProfileThe Oracle BI Open Intelligence Interface ODBC DSN connection must be configured as a new data source profile for the Siebel Enterprise and must be associated with the Siebel Business Application's Object Manager configuration. To configure a new data source profile and associate with AnalyticsDataSrc
Siebel Life Sciences Guide | Copyright © 2016, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
