Siebel Life Sciences Guide > Capturing Adverse Events and Complaints > Process of Capturing and Escalating Adverse Events and Complaints >
Confirming Standard Setup for Service Requests
This task is a step in Process of Capturing and Escalating Adverse Events and Complaints. Before service requests can be logged against products, the Siebel administrator sets up the following:
- Products. Records need to be set up for products against which there might be adverse events and complaints.
- Product Lines and Categories. Product lines and categories can both be associated with codes. If you configure your application to filter codes according to product line or category, make sure to set these up. For more about codes, see Setting Up Codes.
- Assets. Asset records should be set up for devices with serial numbers. Assets do not need to be set up for items such as consumables.
- Activity Templates of type Service Request. Call center agents use activity templates to create service request activity plans—sets of predefined and scheduled activities associated with service requests.
- Solutions. Many service requests are similar to previously addressed issues. Solution documents contain information about previously resolved requests.
- LOVs for Type, Area, and Sub Area. These fields are particularly important for classifying service requests. You can customize these LOVs.
You might have already completed these setup tasks for other reasons in Siebel Life Sciences. These setup tasks are standard in many Siebel Business Applications and are not unique to Siebel Life Sciences. TIP: To aid call center agents with information gathering and problem diagnosis associated with adverse events and complaints, you can set up SmartScripts. For more information about SmartScripts, see Siebel SmartScript Administration Guide.
Setting up Products, Product Lines, Categories, Assets, Activity Templates, Solutions, and LOVs
For information, consult Table 32.
Table 32. Setting up Products, Product Lines, Categories, Assets, Activity Templates, Solutions, and LOVs
And for More Information, See... |
Products |
Product Administration |
Defining External Products and Siebel Product Administration Guide |
Product Lines |
Product Administration screen, then Product Lines |
Categories |
Catalog Administration |
Adding Products to Catalogs |
Assets |
Assets |
Siebel Field Service Guide, Siebel Communications Guide |
Activity Plans of type Service Request |
Data Administration screen, then Activity Templates |
Siebel Field Service Guide |
Solutions |
Solution Administration |
LOVs |
Data Administration screen, then List of Values |
Siebel Applications Administration Guide |
