Siebel Life Sciences Guide > Setting Up Siebel Pharma > About Setting Up Siebel Pharma >
Configuring Pharma Properties in Siebel Tools
User properties are object definitions that are added to an applet, business component, control, field, or list column to configure specialized behavior. Some Siebel Pharma features are driven by user properties. You can customize these features through their respective user properties. With user properties, you can control UI behavior, change default settings or leave them as they are, and enable or disable features. For information on enabling and configuring the Tools object definitions required for Siebel Pharma, see Siebel Pharma Developer's Reference.
