Siebel Life Sciences Guide > Setting Up Siebel Pharma > About Setting Up Siebel Pharma > Enabling or Disabling Siebel Open UI for Siebel PharmaTo enable or disable Siebel Open UI for Siebel Pharma, you must configure the EnableOpenUI parameter for the ePharmaObjMgr_enu Object Manager. For information on configuring the Object Manager to enable Siebel Open UI, see the Siebel Installation Guide for the operating system you are using. |
| Siebel Life Sciences Guide | Copyright © 2016, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
