Siebel Life Sciences Guide > Using Personalized Content Delivery > Using Signature Control for Personalized Content Delivery >
About Loading Signature Control
There is a separate component for capturing signatures in Flex. This component is available in PCD as an SWF file called SignatureCtrl.swf. Signature control can be loaded in PCD using three different modes:
- Mode 1. A signature message is defined on the message plan and the current message has an allocated space for the signature control. For information about configuring this mode, see Configuring Mode 1 Signature Control.
- Mode 2. A signature message is not defined on the message plan and the current message has an allocated space for the signature control. For information about configuring this mode, see Configuring Mode 2 Signature Control.
- Mode 3. A signature message is not defined on the message plan and the current message does not have an allocated space for the signature control. This is the default configuration, no additional configuration is needed for this mode.
