Siebel Life Sciences Guide > Using Personalized Content Delivery > Using Signature Control for Personalized Content Delivery > Modifying Contacts in the Signature ComponentA representative can change the contact to another contact within the signature component. For example, a representative is speaking with Dr. A. A Contact Call Record has already been created for Dr. A. The representative adds sample drop records to this call by clicking the Detail button in Call view. Now consider that the signature was captured for Dr. A and saved. The status of the record has been changed to Signed. If instead of Dr. A, the representative selects a different contact: Dr. B. The signature control will then create a new contact call record in the Siebel database for Dr. B, and the sample records will be copied over to the new call. This new call will be validated, and the signature is captured and saved and the status of the call record will be set to Signed. The module will only allow the representative to change the contact if the validation process confirms that the contact is eligible. Otherwise, an error message will appear. To modify contacts in the signature component
| Siebel Life Sciences Guide | Copyright © 2016, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
