Siebel Life Sciences Guide > Using Personalized Content Delivery >
Defining System Preferences for Personalized Content Delivery
Your system administrator must define the following system preferences before you can begin to use Personalized Content Delivery.
- Server Uncompression Location. Specifies the Siebel Server file path location from where uncompressed message files are cached.
- Decompressed Files Path. Specifies the relative path to cache uncompressed message files when using Siebel Mobile Web Client.
- CheckForNeedToSync. For remote users, only messages with the user property, NeedToSync, set to Y are decompressed. Otherwise, all messages are decompressed.
- Skin. Specifies the theme as custom graphical appearances for Personalized Content Delivery.
For more information about setting system preferences, see Setting System Preferences for PCD. Table 50 lists the system preference values that you need to set before you start using Personalized Content Delivery.
