Siebel Life Sciences Guide > Using Personalized Content Delivery > Managing Content for Personalized Content Delivery >
Associating Attributes with Personalized Content Delivery Records
You can associate attributes such as product name, segment, and so on with the PCD records, so that users can filter records based on the specified values.
To associate attributes with PCD records
  1. Navigate to the Administration - Document screen, then the Literature view.
  2. In the Literature list, select a record.
  3. Click the Applies To tab.
  4. In the Applies To list, create a new record and complete the necessary fields.
    Some fields are described in the following table.
    Field
    Description
    Product
    Select the product that you want to apply to the message.
    Indication
    Use the drop-down list to select the indication for which the message was designed.
    Issues
    Use the drop-down list to select the issue that the message was designed to address.
Siebel Life Sciences Guide Copyright © 2016, Oracle and/or its affiliates. All rights reserved. Legal Notices.
