Siebel Loyalty Administration Guide > German GAAP Statutory Compliance for Siebel Loyalty > Activating the Audit Trail for the LOY Member Business ComponentsBy default, the Audit Trail for Siebel Loyalty-specific Business Components is disabled. In order to meet the regulatory requirements of Germany, you must enable the Audit Trail functionality for the following business components:
For additional information, see Siebel Applications Administration Guide. Enabling the Audit Trail for the LOY Member Business ComponentIn order to enable this business component, you must be logged into Siebel Loyalty as the loyalty administrator with the appropriate rights to modify the Audit Trail configuration. To enable the audit trail for the LOY Member business component
Enabling the Audit Trail for the LOY Tier Business ComponentIn order to enable this business component, you must be logged into Siebel Loyalty as the loyalty administrator with the appropriate rights to modify the Audit Trail configuration. To enabling the audit trail for the LOY Tier business component
Enabling the Audit Trail for the Channel Partner Business ComponentIn order to enable this business component, you must be logged into the Siebel Loyalty as the loyalty administrator with the appropriate rights to modify the Audit Trail configuration. To enable the audit trail for the Channel Partner business component
Enabling the Audit Trail for the Personal Payment Profile Business ComponentIn order to enable this business component, you must be logged into the Siebel Loyalty as the loyalty administrator with the appropriate rights to modify the Audit Trail configuration. To enable the audit trail for the Personal Payment Profile business component
In addition to the above mentioned fields, it might be necessary to audit other fields added during customization of the Siebel Loyalty product. |
| Siebel Loyalty Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
