Siebel Loyalty Administration Guide > German GAAP Statutory Compliance for Siebel Loyalty > Merging Loyalty MembersCAUTION: It is recommended that you do not add fields to the Member List Applet that contain point values, for example, Point 1 Value. If your LOY Member List Applet fields contain point values, then the merge process might not correctly add points. |
| Siebel Loyalty Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
